Vg column shift gears
Coaldust666
22
New Zealand
VG
Just confirming, my vg column shift has 2 drive gears.
I'm assuming the blue one would be overdrive?
Any info appreciated
Sandst4rm
South Australia
VT S1 Calais Ecotec - VP Ute 3800
The blue one is 4th gear (4L60 otherwise known as T700R4)
I bet your selector shows -" 1 2 D [D] N R P "-
My column shift VP has one that shows -" 1 2 3 [D] N R P "- and there is no difference in the transmissions
Coaldust666
22
New Zealand
VG
Yep that's the one. I'll chuck some photos up tomorrow, vg and vp wagon both colum shift
Sandst4rm
South Australia
My bad apparently, I have the same as you but i dont use mine so shows how good my memory is.
I was thinking of the VR-VS column shift "Quadrant selector"
It really makes little difference to the actual operation;
Dropping the gear into the white D will drop the gear into 3rd if cruising in the blue [D]
there is also no way to hold a gear unless you modify the gearbox electronics as it will always shift at rev limit even if in 1st
Coaldust666
22
New Zealand
VG
View attachment 266270View attachment 266271
So it's pointless essentially? Lol
That blue interior!
Sandst4rm
South Australia
The point of it to begin with is to show you what gear youre in if you are an average joe, I just am familiar so i go by feel.
The point of the 2nd D is idk man, couldnt afford any number 3 stickers or something at the factory
Coaldust666
22
New Zealand
VG
No #3 stickers :cool:
Took that vg for its first drive since April last year and went smooth as. I was impressed with how quick it is to switch gears
Sandst4rm
South Australia
Now that i think on it the T700 might hold a gear if you move the kickdown cable all the way in on the intake manifold...
On the black plate; middle of the intake manifold there are 2 cables usually, one for accelerator pedal and one for kickdown.
You can push the little metal half moon shape in; then pull the cable in and out to change what revs the box shifts at. So you can do hectic 1st gear burnouts!
Forget which way increases or decreases
