VG fuel gauge sender question
shadow82
41
morayfield
vx commodore
Hi i need to replace my fuel gauge sender in my VG ute will a sender from VN-VR fit or does it have to be a VG/VP one?
])AVO
NSW
VT, VG
They should be the same
vaxx
Queensland
VN Executive S1 Sedan, VR Ute
IIRC, they are the same (sure all sender output the same from VN to VS as there is little in a dash cluster change). Horrible thing to get out too. Easiest to remove the whole tank and sit it on the edge of a table to get the sender out as it takes a little maneuvering :D
kennedy1207
australia
vg commodore ute
i have the same problem did you get around to a solution my biggest problem that I face is most of your vp/vr senders are top mount compared to the side mount my vg is a 1991 Ute and no one seems to stock the specific fuel sender unit.
MikeC
VQ Statesman
The poster was last here in 2015. I'm pretty sure my VQ sender/pump unit is mounted on the side of the tank.
