VG to VS ute Subwoofer enclosure with measurements
fuzzy2308
Plastic datsun
brilliant thread mate. it will be very helpfull (when i put a new donk in mine)
Vg-ute-mad
51
Whalan, N.S.W
VS 97 Series II
Thanks heaps mate! I'm glade I can help! :thumbsup:
schteven
vz wagon
doest that trap door not leak is it ment to have a seal?
Vg-ute-mad
51
Whalan, N.S.W
VS 97 Series II
I put a bead of silicon around the edge and let it dry before screwing the lid down.
I also made sure the inside of the cavity was also sealed so the sub wouldn't get water damaged.
mr_sikma
REXXXY, SIKMA, Kia Rio
or buy this that suts behind one of the seats for about $150-
DNA Designer Audio : Sub Box Enclosures - Car Audio & Accessories
Vg-ute-mad
51
Whalan, N.S.W
VS 97 Series II
34
Cairns, QLD
VS S Pack Ute
Is it possible to adapt this and make a sealed enclosure with a port going straight into the cabin through one of those holes? Would make for better sealing imo, I'm just not sure how to go about setting a box up for that.
Vg-ute-mad
51
Whalan, N.S.W
VS 97 Series II
To make a ported enclosure with the sub specs that I used, you would need to make the enclosure larger. Which would be hard, as there is limited space as it is.
Oh and 128 degree's? What the? From where?
If you are looking at the enclosure side on, from bottom to top, it is a 128 degree right angle.
kendawg
VS Commo Ute
hey mate i like your design... thinking of using it... but i have a pioneer 12" and the diameter is 327mm (16mm bigger than the fusion one), and the depth is 164mm (36.5mm deeper than fusion). As i cant really see how close the magnet is to the side of the box, do you think this sub will fit? if not, do you have any suggestions to make it fit? such as changing the angle, etc. thanks in advance for your help.
