VG Ute problem: cd player, tacho stays on when key is out of Ignition??
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by zacatrain, May 18, 2008.
  1. zacatrain
    zacatrain New Member
    VG Commodore ute
    I have a VG ute and when i turn the keys off the cd player ad taco stay on, and when i go for a five minute drive my battery will be dead, need help.............
  2. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    ok, tacho not turning off along with CD player is going to indicate that your car isnt switching the acc circut off properly... External tacho id imagine or else it means your ign relay isnt turning off either.
    Prehaps faulty relays but also a faulty ingnition switch.
    I i were you, id pull my steering coloumb off and then remove the switch at the rear of my ignition barrel, then using a screw driver, id turn the car on and then off again and see if the problem is still occuring.
    That will eliminate the barrel. If it is still doing it, replace the acc and ign relays. If its still doing it....reply here and ill think of something else..
    aZk.
  3. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    Sounds to me like your aftermarket(?) cd player and tac were put on a +12v battery line, instead of the +12v accessory line.
    Also, How old is your battery?
