NICK307
VH-308-A9L--308 VK BLOCK--A9L SUMP--308 A9L GRP A CRANKSHAFT--GRPA STEEL 2 BOLT MAIN CAPS[stamped hdt;square caps]--ARP STUD KIT--
A9L GRP A CONRODS [spike rods with arp 3\8 bolts]--308 GRP A PISTONS @ RINGS[standard bore size]--ACL [MAIN @ CON ROD BEARINGS; ACL CAM BEARINGS--JP HI VOL OIL PUMP--CRANE COATED GEAR 4 oil pump--FEL PRO GASKIT KIT--POWER BOND RACE BALANCER--COMP CAMS HYD CAMSHAFT[duration 258 .50. valve lift 570+]--CRANE ANTI PUMP LIFTERS--JP DOUBLE ROW TIMMING CHAIN--GILMER BELT DRIVE--POWER BOSS WATER PUMP[big bearing pump]--308 BROCK GROUP A X HEADS A9L[PN 92032422--28K6] CRANE GOLD ROLA ROCKERS;;HDT GUIDE PLATES;;L34 VALVES;;SCREW N STUDS;;CRANE DOUBLE VALVE SPRINGS;;FACTORY PORT AND POLISH;;square poulution port]--308 GROUP A A9L BROCKY MANIFOLD 955 MODIFIED--B-G 750 DOUBLE PUMPER--1 INCH SPACER--PRO COMP 14\3 AIR FILTER--HEI GMH INGNITION--MSD BLASTER 2--CRANE MALTI SPARK DIGITAL BOX--308 GROUP A EXTRACTORS[stamped HDT]--16 INCH THERMO--308 ENGINE IS A MATCHING NUMBERS A9L GROUP A 1986 MODEL AND BEEN FULLY REBUILT AND BALANCED has not been started yet--
