markovr
- Nov 23, 2003
- 3,072
- 252
- 83
- Age
- 62
- Location
- northside brisbane
- Website
- youtu.be
- 07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
I used the vt/x/y mas/booster upgrade on vl turbo style front brakes and std vn rears on my vh just as a fix to a dodgy 1 inch master cylinder that was filling the booster full of brake fluid finally trashing a diaphram in the booster (giving you a huge scare when it went the first time) The upgrade gives soo much better pedal for less than it cost to replace with the original equipment........also you get the fast fill and direct action on front piston by the booster pushrod (cause it is at the back on a vt/x/y cylinder)The pedal is so good after you get used to it that before when the lights turned red in front of you....... you slammed them on and maybe pulled up just over the line with your heart in your mouth ...now the lights can do whatever they like cause you know you can stop.
