VH Commodore carby problem?
bigfella99
54
My VH Commodore wagon has developed a problem. It is a 2.85ltr 4 speed manual all standard.
Vehicle starts first time every time from cold.
Running standard unleaded with flash lube
Under heavy acceleration it coughs and splutters and eventually dies, leaving a fuel smell. I cannot restart immediately.
Under normal driving from cold start I can drive for about 15 minutes no problems then vehicle dies, leaving a fuel smell. Attempting to restart can be a problem sometimes it does and it will not hold idle.Sometimes it will sound like a backfire under the aircleaner.Sometimes it wont and I wait and restart after about 10 minutes.
Items that have been checked and replaced
Air cleaner
Ignition leads
Spark plugs- New plugs have a carbon(black) deposit on them after this problem occurs (cleaned and reinserted)
Distributor and rotor.
What is next?
This is driving me nuts
If anyone can assist in solving my problem with a how to do description. It will be most appreciated.
VHSLX3300
VN S Pac VH SL/X
could be the jets in the carby are blocked. have you changed your fuel filter?. I dont know much about these but I know the slightest bit of crap in the carby will affect it big time. Carby rebuilds are fairly expensive maybe look at upgrading it to another type e.g. a holley
tigervh
SS.....smokin....!
Newcastle
Tiger Mica EFI VH, VZ SS, XC Barina SRI
Sounds like either the fuel pump or fuel filter. another possibility is the needle and seat.
bigfella99
54
I havent replaced the fuel filter.
Timing is set a little out to compensate for pinging
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
have you tried to run the car on PULP instead of the regular unleaded?.
bigfella99
54
have tried other fuels - no change- problem still occurs
tigervh
SS.....smokin....!
Newcastle
I,d replace the pump before anything else.
