that goes to the the canister bundy line, from memory there should be a check valve on the rubber line that plugs into that fitting.Trying to replace vent lines but don't know where this outlet pipe goes too??
Thanks. Hi do you have any other pics . Of the tank air vent lines . I think the spare 1 you have is a return back to the black canister in the engine bay . Mine has a line runs all the way to the neck . Mine doesn’t have that black thing on the neck. CheersTrying to replace vent lines but don't know where this outlet pipe goes too??
Ok thanks I will give that go . CheersI used this to figure mine out mate
