anf355
- Nov 6, 2018
- 29
- 2
- 3
- Location
- victoria
- VB Commodore
Hi there,
Having some problems, I just purchased a VB commodore, it is without issues. None of my instrument lights work, after a little researching I decided to fit LED globes, everything worked except the top right globe nearest to the tacho/oil T plug , upon starting my car I noticed the oil gauge drops and sits low and the Tachometer behaves erratically now, jumps, then works then stops. I bypassed a couple of wires from oil sender and coil to rule out if I damage the original wiring but still the same result, to top it off, after removing the cluster multiple times in and out testing with the screen off, I snapped the speedo needle about a 3rd off (so fragile) im currently trying to glue that back on, also found heater core leaking needs replace, heater blower fan also buggered, all this a week before going for a roadworthy. Sheez!
could I have ruined my cluster? I read somewhere these LED globes are ok to use. Ive been looking for clusters, seen a few for VH, is the wiring schematics the same as VB or will this require mods? I was thinking VH cluster with VB fascia? does it work? are the instruments removable if I was to buy gauges separately?
Also, Does anyone know if the heater wires ( tan yellow or orange) returning back from the blower fan to the heater switch, should they have any power, I only have power running through the brown wire to the blower but nothing out. Could it be a blown resistor, maybe I could bypass the resistor to have it as a simple single speed on off switch, I am due for the roadworthy soon and cant find a VB blower fan. Is there a way to test the blower or even the switch separately.
Sorry for the overload of questions, im not as manic as I read. hehe!
