vh..problems after problems
hellsvk
vk 202
hey guys,officaly had enough of the problems thats happening to my vh,i had a mc6 torquemaster in there and now have converted it to a m20 aussie 4 speed..wen i connect the clutch cable theres so pressure in the pedal..has anyone put a m20 behind a red 202 in a vh?
hellsvk
vk 202
have you tried adjusting the clutch fork, pivot ball ?
ill try it now..i also got told the xmember from the mc6 will sit ok for the 4 speed,but it seems to sit to high,and the tail shaft seems to be to short
vkberlina
VK Madman
44
NSW Central Coast
www.members.westnet.com.au
im sure its the same gearbox mount & xmembers between the two. You will need a different front part of the tail shaft though, I think I have one sitting here but its on the other side of the country :)
scott
Guzzoline addict
vr v6
Did you use the mc6 clutch?Not a 100% sure ,but i think the throw out bearing is different.
hellsvk
vk 202
hey mate got the longer tail shaft,yep i used the mc6 bearing,i started her up today in neutral and sounded like the throw out bearing is pressing,its making a grinding noise!
