VH rpm at 100kmh
42
Wollongong
VH SL Wagon
I have a GU6 diff in my VH wagon which is a 3.36 Small Salisbury
at 100kmh i'm at 3150rpm and at 110kmh im at 3500rpm
M21 4 speed, 253 V8
from a diff calc looks as though its 3.9 ratio, I though small salisbury diff went 3.36, 3.55, 4.44
must be a faulty tacho i think
SL/ENUT
The SL/E Fanatic!
39
Burnie, Tasmania
VB SL/E 5L
Going though my commodore records stuff, GU6 was never fitted to a Commodore, never a Holden option.
My understanding is the following
GU4 3.08:1 on both ten bolt and 8 bolt Sals diffs
GV4 3.36:1 on both same diffs
GU7 2.78:1 on 8 bolt diffs
GU8 3.90:1 on 8 bolt diffs(common on the Starfire 4 powered ones)
GV7 3.55:1 only ten bolt diff
G70 2.60:1 only a ten bolt diff
4.44:1 is a ten bolt only diff, used only in the one tonner cab chassis-HQ-WB
42
Wollongong
VH SL Wagon
i meant GU4, maybe its got a starfire diff, i'll have to jack it up and check the rotation
42
Wollongong
VH SL Wagon
sorry GV4 i just looked at the vin plate
Guzzoline addict
vr v6
The speedo or tacho might be out,have you got a Automotive Multimeter and some sort of gps to check?. Also what code for the engine is on the vin?, if it was a 6 check if the tacho has been switched.
42
Wollongong
VH SL Wagon
the car was a 2.85l 6 with a vacuum gauge, the dash was out of a VH V8 but that was already fitted when i bought it. I do have a multi meter with tach and gps on my phone so i can double check next time.
42
Wollongong
VH SL Wagon
i don't have access to the car yet pick it up friday however i did some googling and the speedo drive gear is a light blue 24 or 25 tooth which is meant for a 3.9 ratio, the speedo reads true so i'm thinking it has a 3.9 ratio fitted, i will double check though. i will end up with a VL 3.45 BW later after i can find one local, already found a VS diff with disks but will fit these to the VL diff once i find one.
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
Those revs sound right for a 3.36 diff and 14 inch wheels. My old HT Kingswood used to sit on 3500RPM at 70MPH with a 3.36 diff.
42
Wollongong
VH SL Wagon
picked the car up today, got it to 110km on the gps (dash is spot on) and its was revving at 4100rpm and at 100kmh it was about 3700rpm... i can drive everywhere in 4th gear its almost as bad as the old 2.6 diffs that could do 120kmh in 1st gear.
i'm pretty sure its a 3.9 ratio but i will remove the cap and change the oil and check soon
