RD 400
With an OEM setup, for a given brake pedal stroke, you get a given master cylinder stroke, the length of which depends on pedal leverage. Changing the OEM master cylinder to a smaller diameter means that with the given master cylinder stroke, less fluid volume is move compared to the ODM setup. As such you can’t get a higher line pressure than when the OEM master cylinder is used..I have experimented with different size MCs and the smaller bore definitely places more pressure on the caliper pistons and pulls you up quicker. The smaller bore also flexs the lines more. The larger bore generally is used on twin piston or more piston calipers. A large bore MC on single piston calipers and standard booster and all else being the same will feel like a rock.
Hydraulic brake theory is exactly the same* for motorbike, motor vehicle, push bike, etc. Unless I’m missing something.big difference cars to bikes
Happy to be corrected but how can it vary much? I would think the same principle applies? If the MC was identical except bore diam how can a smaller diam one not be higher pressure like it is on a bike? Are the car ones operating in some different way, asides from the booster?big difference cars to bikes
clearly it can not be because on a bike if you run a smaller diam MC your brakes will pull up a lot harder. I have tried it and plenty of other blokes that race use smaller MCs to increase the pressure on the pads. My bike mech runs one off a dirt bike which are really small but the force is far greater than mine and he uses the same calipers as me.Hydraulic brake theory is exactly the same* for motorbike, motor vehicle, push bike, etc. Unless I’m missing something.
* ignoring proportioning valves
I updated my post above... explains the principle which I misunderstood/forgot/got too old...Obviously there is a limit but when I run the 9/16 MC it pulled me up quicker than the 5/8. Some go as low as 1/2 but that would be about as low as you would go. Yes there is less fluid but volume doesn't equal pressure on a bike at least. Now i have no idea how the science works., so i can't explain how it works.
I got the bracket from the wrecker when I got the booster.I've had all combinations on my VC...single diaphram booster, with both M/C's and double diaphram booster with both M/C's....
The only difference is the bolt positioning on the strut tower.....The bracket is identical, however if you change the booster from one to the other, from what was originally fitted, you'd have to modify the bracket to suit
