vc commodore
- Jun 18, 2014
- 10,727
- 12,617
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
I think your problem was caused by the booster having too much pushrod length and after a few applications it was not allowing the cups in the master cylinder to come back far enough to expose ports for the fluid to return to the reservoir...so it sort of like driving with your foot on the brake pedal.
I have found when a booster fails it can cause excessive travel but also then it can also make the brakes slam on right at the floor depending on wear dimensions and tolerances but the problem wont disappear when you try to bleed the master cylinder like you have.
One thing I didn't mention in the original thread was the original booster actually gave me a hard pedal on start up, hence the change to the one in the thread and the insuing problem.
That being said, yes I do understand what you are saying and I actually did some further enquiring about booster interchanging inbetween models, as the one in the thread didn't have an adjuster....So I wasn't limited to a couple of model commodores for another booster and was able to get another to fix the problem....
So I can make the assumption, a failing booster can cause both issues...Both hard and soft pedals?....
