Vh vn heads alternator bracket
Acr001
46
Dubbo
Vhss
Hi all I have a vh now fitted 355 vn heads what's the best option for p/steer & alternator location with out moving battery any help would be much appreciated cheers
gtrboyy
vt ss & lc gtr
Depends on the crossmember & rack you're using.
Early rack/crossmember use those & deal with extractor clearance with alternator/bracket + rack near the sump
Or later rack & crossmember then cut battery tray for clearance...essentially vn-vs underneath.
Had vh crossmember,powersteer with modded aircon bracket for alternator to clear extractors but still touched rack where they go near sump...ended up going manual steering instead of changing everything over to later model vn-s underneath.
