Hi all, i have a dam annoying vibration humming sorta noise that comes and goes, it sounds like it is coming from the passengers side front guard area, whilst driving if i stop it will happen but as soon as i start to accelerate the noise goes away, once i am doing over say 10 klm per hour the sound goes away completely , sometimes even if i am stationary & in " park " with the motor running it will start making the noise but then but if i wack it in neutral the sounds stops, i have had a look around but buggered if i can work it out were it's coming from. any thoughts anyone ?? thanks
update, i found the trouble, so just in case it happens to anyone else here, inside the front left guard i found a piece of rubber tubing laying on a ledge, just below [ i think the brake fluid tubing ] that goes through the wall & down to the front brake area, once i grabbed the metal tube the vibration stopped, so the rubber tube must be there inside a metal bracket to stop the metal vibrating [ metal on metal ]so it was in a tricky spot to replace it so i just some silicon inside the bracket stopped it straight away, thank god.
