boojak87 said:I was told it's normal for a VS to shudder under hard acceleration. . It does get to be a bit of a pain in the ass sometimes though because usually you associate the vibration with stress and it's struggling to keep up. If someone could pinpoint the problem and give a fix it'd be awesome. Thanks!
phatwagon4u said:if you have symptoms like this it sounds like the transmission mount has broken,at the rear of the trans there is a rubber mount where it bolts the trans too the chassis,
what happens is the rubber mount seperates from its metal mount (they are glued together),so it creates a thud when the engine is under load.
they only way too check if the mount is ok is too remove the mount and bracket off your trans,if it is fu#ked it will fall into 2 pieces
hope this help
