Vibration when going over 100
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by 300, Mar 18, 2009.
  1. 300
    300 New Member
    VT II
    We did hit a kerb some weeks ago and since then went through 2 sets of tyres cause they were wearing out as ****. had some wheel allignments done and brought the car into a mechanic yesterday.
    what they've done was:
    front disc rotor machining pr,
    front disc pad commodore,
    and then:
    NOL ADJRADIUS ROD BUSH KIT F+R,
    ACE ALIGNMENT FRONT
    what we're having since then is a really bad vibration and the back tyre seems to have slight movement in and out when hitting 90 or 100.
    any ideas whats causing that?
  2. ACEMonkey
    ACEMonkey New Member
    1998 VT Acclaim S1
    Probably something bent or loose. Best not to hit a kerb next time.
  3. Promotec
    Promotec Member
    Gold Coast Queensland
    2010 VE Commodore International Dual Fuel LPG / UL
    Hi there
    By what you listed you havent had your wheels reballanced, this would definately give you a vibration over 100+klm youve done the hard and expensive stuff but the simple aspect appears to be overlooked.
  4. vxcalais_01
    vxcalais_01 Active Member
    VX Calais 3.8
    Your wheels/rims could be buggered as well. If they can balance the tyres then you should be fine.......
