vinyl interior spray
WILD VR CLUBBY
lack of licence
Melborne
2004 vy s
i went over mine with clear and its lasted a couple of months so far so that might be the way to go
89vncommy
www.cardomain.com
VN Caladore
I used it on an old Pulsar of mine.. Changed the interior from Blue to Black ... Did all door trims and roof, but not dash ... Had it on the car for a good six months, and had no probs with it. Never peeled nothing... I wrote the car off, so don't know how it held up after that...
Bax
Projecting
40
QLD
Nothing
It's all about the prep when you put it on.
I had black vinyl spray on my dash. Prepped the surface really well, took it all out, sanded it, washed it with metho and then water. Then did three coats and it lasted 8 months with not even a scratch.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
dont know if this has been discussed b4 but does anyone know a way to stop vinyl spray from eventually flaking off if you've sprayed your interior panels etc.. with it??
What Bax said. I have cleaned up a couple of cars and my brother changed the colour of his WB van. It's all in the preparation. Make sure everything is super clean using the recommended chemicals and it will last for years (the van lasted over 6 years before he pranged it).
Reaper
Torquen
Boost FTW
35
Perth, WA
450+ HP FORD XR6T
whats a good procuct to use. that latest SC issue had some proct called SXR or sumin like that.
02QIK
1TUFVS
Toowoomba, Queensland
VS Executive S2
When i done my gemini ages ago... I used vht vinyl dye... Did try a vinyl spray, but peeled, so bought the dye and that worked million times better....
Bax
Projecting
40
QLD
Nothing
Thats what I used, VHT vinyl spray. and I've used K&H on the current dash.
SWE11L
VS Berlina/ KJ Verada/ 88 Trans Am
thx for the tips, i tried it a few years ago on my VL, went from beige interior to dark grey and it looked great but around arm rests and door sills wore off pretty quick, i used vht too..just needed some tips before i absolutly rooted my VS interior!!
