VK 308 berlina questions
Stretchomatic
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
hey guys, recently picked up a vk 308 that had been sitting for a month or two. done a service and it runs fairly good. just a few little things that i would like to iron out.
1. when u give the throttle a sharp hit it nearly stalls, though if u ease on the throttle or tap it quickly a few times it revs not bad. spraying carb cleaner definitely made this a lot better, but still does it.
2. stalls when put in reverse, on an up hill slope it wont reverse, goes fine down hill lol.
3. tacho and temp guage dont work, where are they picked up from and what does the sensor look like? i'm pulling the dash out soon to check the air con and what not, so i'll have a look there.
im sure there is other little things, but i can remember right now.
any info would be great, cheers
jason.
Paiste402
My workin on the car face
Normanville SA
1992 EB Fairmont Ghia
check ur timing mate, this can throw the motor out of wack pretty good. I would aim for around 10 deg advanced and see how you go. Check all the spark plugs or better yet replace them all. Look under the dizzy cap and see how the contact points look, also the rotor button, those can cause some rough rides. Make sure all the vacuum hoses are good, since carbs rely solely on vacuum a vac leak will throw it out also this being a black 308 there are HEAPING ****-TONNES OF VAC HOSES, i should know ive got one :bang:. Get a new air filter if u havent already, $10 well spent there :yeah:
And with ur reverse problem you must be low on auto fluid (im guessing its an auto :D). Park it onto a flat surface and put a brick on the front tires. Start the car and put it into D and then pull out the dip stick-wipe it and then check the reading. You have to do this cause the torque converter sucks the fluid from the trans pan and puts it through the trans lowering the fluid level in the pan. If the car is off and u check it it seems litres over filled.
Here is a pic of where the temp sensors are, not much to them really. Just a wire that is connected to them. The tacho runs off the electric signal on the ignition coil for the dizzy. Not sure which wire this is but maybe someone on here can enlighten me.
Thats all i can think about right now mate, but let us know how it all goes :thumbsup:
Stretchomatic
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
yeah mate, new plugs and leads, new oil, oil filter, fuel filter, air filter, and yeah when i cheked the auto fluid it seemed over full, but then i read that i'm supposed to run till warm, shift through all gears then turn off and put the dip stick in and out quickly before it all flows out of the converter and gears and such, so atm i guess its full. i will check the level tomoz properly. the vaccum hoses have me stumped, stupid manual doesnt label them all so i'm not 100% sure how they go.
either way, tomorrow i'll give it all a look over.
cheers mate.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Paiste is on the money.
Another reason for it stalling in reverse (but normally in D aswell) is the Vacuum line going to the trans can get blocked with crap and cause it to stall, worth checking.
Scott has Vacuum layouts on his website, if they arnt clear enough, then I can send them to you if you PM me a email.
Scott's website, hes also a member on here so if he sees this he should be able to help you out.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
For the Tacho, the Green wire should be going to the Coil, the black to a ground(earth) and white to a dash panel light, but thats for aftermarket, not sure on factory, let me know if you want me to check.
Paiste402
Normanville SA
cheers mate.
hmmm its best to leave it running in D to get a true reading, cause turning the car off never worked for me, had to keep her runnin. Hmmm well since uve done everything else i reckon tom is right with the trans vac line. Get some ramps and its at the back of the trans near the tail shafts beginning into the trans. Also i would pull each vac hose off one at a time and check for softless/brittleness and cracks and then place it back. Get a white paint pen and mark the cracked or in bad nic ones and replace them later. If u put them back afterwords one at a time u cant mix em up :D
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
:thumbsup:
The best investment when working with Vacuum lines, its like a white out pen, but called a white permanent marker lol, you will quickly learn how valuable it is.
Paiste402
Normanville SA
:thumbsup:
a tool box MUST HAVE! saved my arse when i had to remove every single vac hose at once when doing bad head gasked on my 308. not bad for 19 years of age :D
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Oh come off it, I was 17 when I did my first head gasket :p
My white pen stays locked away in the tool chest with all my good tools lol.
Now Ill stop spamming this guys thread right after I post some hardcore porn...
Paiste402
Normanville SA
hahahaha maate thats alot of pens! **** just remembered that i need a new one. and 17! not bad at all. come think of it i done the gaskets last year so i was 18.
