Thanks for that vin budget is no problem build costs aren't far apart in nz. I like the idea of the LS for its reliability and power but also like the factory holden motor originality and sound,tough 1
Yer its hard choice,
heart says 308 for sound n feel but
brain says LS power regardless of money as either way your pocket will be lighter. So find another VK car and do/have both engines, best way in a dream world.
Also bear in mind what look/originality you want your bay to look like and I would say the LS is an easier look in a vk as you can keep your battery and washer/radiator bottles plus a few lil other things and most wiring is there as well in efi car.
A lot of people think of wanting/doing efi conversion in gen1 cars but
most don't finish it properly as they realize all the bullshit things you have to change so car won't annoy you if something is dodgy, you are virtually changing everything from tailshaft, gearbox member/mountings, speedo cable/speed sensor/shifter, tank/fuel pump/lines/wiring, steering box/intermediate shaft, accel cable, relay box/fuses/ecu/battery boot relocation, radiator/maybe mounts, aircon fittings/relocation, cat/exhaust, and stronger/better diff as well, so in the end just to make it look slighty factory stock your replacing nearly everything and its a long haul.
The 308 is easier and quicker to change and parts easier to get and looks more factory, good luck which every way you go.
I did 99% of the conversion work myself but if I had to pay for it and had the money I would go LS for the extra kw's and wouldn't worry about the look of bay, The Ls has more potential power increases as well today in the market, the 308 is basically limited and getting deleted from the workplaces/shops so thing of having/keeping the car and mods say in the future ??
