Vk 355 Alternator
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by Corey 355 vk, Feb 23, 2018.
  1. Corey 355 vk
    Corey 355 vk New Member
    Eagleby
    Vk 355
    Should I pay someone to rebuild my alternator or should I just do it myself?
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    Depends how much tools/experience you have if its a bosch, the brush/ regulator can be changed over easy and bearings are just nuts and bolts and basic taking 2 bearings off and on . A auto elect would probably turn the slip rings down but that isnt a necessity.
    Old_School and Corey 355 vk like this.
  3. Corey 355 vk
    Eagleby
    Vk 355
    I was having a closer look at the alternator and found this wire that leads back to the alternator. I’m wondering if this is why I am not getting charge through to my battery. I originally thought my alternator needed a rebuild due to not charging battery. What do you think?
  4. gtrboyy
    gtrboyy Well-Known Member
    vt ss & lc gtr
    Looks like brown wire that plugs into back of alternator it's for dash charge light in dash.
    If factory 55A alternator struggling to keep battery charged up just upgrade to bosch v8 vn-vs 85A
    Chassis rail lip doesn't look tapped down underneath alternator ...6cyl bodyshell?
    Old_School likes this.
  5. Corey 355 vk
    Eagleby
    Vk 355
    post: 2951142, member: 21948"]Looks like brown wire that plugs into back of alternator it's for dash charge light in dash.
    Chassis rail lip doesn't look tapped down underneath alternator ...6cyl bodyshell?[/QUOTE]
    Hey mate I have a 85a alternator
  6. Corey 355 vk
    Eagleby
    Vk 355
    Hey mate I have a 85a alternator[/QUOTE]
  7. gtrboyy
    vt ss & lc gtr
    You checked if alternator is charging with multimeter? Battery voltage good or needs regular trickle charge from not being driven?
    85A alternators are good..brown wire to charge light,usually need diode if running msd/crane...white wire to 12v battery supply or loop to alternator stud.
    Other than that sometimes voltage regulator go haywire...either replace or take out & clean 2 prongs
  8. markovr
    northside brisbane
    the brown indicator light definitely needs to be continuous and connected and conductor not touching the body for the alternator to charge and have a good bulb on the dash light
