VK Aftermarket Electric Antenna
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by VK85SL, Oct 1, 2019.
  1. VK85SL
    VK85SL New Member
    Doncaster
    1985 VK Commodore SL
    Hi guys Im after some information on whether anyone has managed to get the aftermarket Aerpro antenna working with the existing electric antenna module for specifically the VK Commodore. I have complete setup from harness, to brand new module and connectors that go with it but not sure whether the VK requires diodes or whether its just plug and play. I do want to be able to control it from the dash switches also.
    Any help would be appreciated.
  2. DerekP
    DerekP Member
    VH SL/E 5.0
    You will need a semi automatic electric aerial to control it from the dash switch, which as far as I know are very rare and extremely hard to come by. There is a thread on here which describes how to modify a fully automatic aerial but an auto elec I took it to said it won't work (never tried it myself as I know nothing about electrics); the chap who wrote the thread said it worked for him.
  3. Trevor loves holden.
    Trevor loves holden. Active Member
    vs commodore
    So what have you got ? is it semi or fully mask kit?
  4. Trevor loves holden.
    vs commodore
  5. DerekP
    DerekP Member
    VH SL/E 5.0
    I have also been told by Auto Elecs the module is controlled by the original SL/E tape deck and aftermarket versions do not support the semi automatic functionality.
    Great to see Semi Auto aerials are available again (I gave up a while back). Now all I need is an original tape deck unit and I am back in business!!!
    VK85SL likes this.
  6. Trevor loves holden.
    vs commodore
    Don't know about that its just a + signal wire so the buttons can activate. You should be able to run the wire to accessories all the switch does is reverse the polarity.
