VK air con
1985VK
Australia
VK SL
Who's got a working air con in their VK? How is it running?
1985VK
Australia
VK SL
1985VK
Australia
VK SL
R12 was put in years ago when the drier was replaced.
I had to take the control off the dash to replace the vac lines
which was a bit involved as some numbers had fallen off.
Another thing I did was take the control apart and cleaned the slides with metho
and clean the blower fan as it had leaves and stuff in it.
Another thing I did was got 5 small hose joiners and extended the factory vac lines and renumbered them,made it easier to reinstall the control.
Vk Berlina has done a air con feature on here.
God I love my VK.
Looks like you may be one of the few survivors.
gossie
Gold Coast.
VE International 3.6L
I had a VK last century and the aircon was fine thanks.
1985VK
Australia
VK SL
It's about living in the now dude ... not living in the past ...
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
When I first installed the 4.9 V8 (into my VK SL 3.3 EST donor) & had the a/c re-gassed, at normally driving speeds it was good but at low speeds or stopped in traffic it wasn't very effective at all. After speaking with an AC expert he advised to replace the small factory 2 blade AC condenser fan with a larger 10 inch SPAL skew pusher type. Made a huge difference, only issue now is the compressor is a bit noisey!
1985VK
Australia
VK SL
Was it regassed with 134a or something else? Did it need flushing and a new Tx valve etc
Lacksballs
www.youtube.com
When I fitted the engine & connected the AC up, I put in a new dyer in then & had to have the test points changed as the machine could only accept later 134a fittings. The system was vacuumed & tested, oil added then recharged. Tx value is still the original (to the best of my knowledge).
