vk brock hdt cold air tray
nighttraintc88
vk calais
Any One After A Cold Air Tray For Vk Got To Link To Have Alook
nighttraintc88
vk calais
http://cgi.ebay.com.au/ws/eBayISAPI...sspagename=STRK:MESE:IT&rd=1#ebayphotohosting
sk00bs
39
sydney
vh sle
anyone got some instructions on fitting one of these, i am guess there is very little to it but still.......
cheers
GreenGremlin
www.brockcommodores.com
VK Calais
you need to cut the fan shroud a bit, cut out the top section in the middle but leave a little on either side sitting up proud from the radiator, this will help locate it, the carby end is atached with some rivets etc to the underside of the bottom part of the aircleaner assembly, follow your nose, they rent hard to install but like anything measure twice before doing anything permanent.
vee ka
'85 HDT VK SS, '03 Liberty GT, '06 Forester XT
ahhh no! you dont need to cut the shroud at all, the tray sits over the top of it all and you dont pop rivet anything to the carbie area at all, either the air cleaner or the tray. the tray is held in place at the front with two "L" shaped metal tabs that screw into the radiator top and at the carbie by the air cleaner assy. you locate it by the tabs at the front and screw it in place, put the bottom section of the air cleaner on top of the tray, then air cleaner, then tighten the air cleaner top down. you dont cut anything or pop rivet the tray to the air cleaner housing!!! how do i know, i have a genuine brock commodore with a genuine HDT air tray
44
Wollongong
VH SL Wagon
old thread but i need help too, the aftermarket tray when fitted with a fan should pushes the shroud onto the fan when the bonnet is closed so i can understand why the shroud needs to be cut but i chose to ditch the tray instead, plus if the tray is not riveted to the aircleaner the tray sits on the vacuum hoses and throttle cable. a genuine tray and aircleaner is probably different to the copies you buy from rarespares and ebay.
can someone post some pics??
