vk calais ignition errors!
benjiaka
You Gon Ride or die?
Adelaide, Australia
Vk Calais 1985
warning light comes up on my vk calais, ' low coolant ' and ' low oil '
But neither are low?
:S
NORTI
Radelaide
Wildtrak
sensors are stuffed.
NORTI
Radelaide
Wildtrak
depends, you will prob find that the coolant sensor is corroded pretty badly. Im not even sure they are available new anymore. The oil one may have become heat damaged
NORTI
Radelaide
Wildtrak
the warning beeps will keep going if there is no reading at all from the sensors....
Ill try & get a pic from NUFNSUS for you as I dont have a VKC anymore :(
DANNY8
Yo Coooornflake!
37
Port Pirie, South Australia
www.kerrbrosracing.com
VK WAGZ 5.0L, GQ Patrol TD42
This is from someone I know that works in the parts area at our local Holden.
theres 2 types of coolant level sensors the v8 and 6 use the same one but one of them has a "Pin Terminal" and the other uses a "Blade Terminal", both of which are available for under 85bux each
Wrayza
VK Calais
Under your dash should be a moulded white/brown coloured circuit board about 30mmx30mm. Removing this from its socket will stop the low coolant warning, and I'd quite confidently say it will also stop the oil one, give it a go.
