Triff
Probably dumb question but I've never done wiring **** with cars aside from direct replace wire for wire. What exactly is the ecu in vk's for? Do I need it seeing I'm going to be running an ls2 with msd box and carby?
Vk ecuLs2 ecu or the vk efi ecu ??
the vk ecu runs the engine efi systemVk ecu
So seeing im running carbed blown with msd I can remove ecu completelythe vk ecu runs the engine efi system
Ls2 has its own ecu to run efi engine management
A 6cyl ecu wouldn't run the ls v8
carbies don't need a ecu neither does a bear who sheets in the woodsSo seeing im running carbed blown with msd I can remove ecu completely
Yeah just needs the msd box to run the coils. Know all that bit wasnt sure if removing ecu would hinder any other wiringcarbies don't need a ecu neither does a bear who sheets in the woods
