VK: Indicator problem
Kris_man
VK
I have an 85 6 cylinder VK...
Hazards work
Wipers work
High beams work
Indicators don't work!
When I push the indicator stalk down, it doesn't stay down, but the flasher can does click once.
What would the problem be?? Help would be much appreciated.
Kris.
ssute57l
45
VYII SS UTE
To check if the switch/fuse is working, find your flasher unit, remove it, bridge the terminals X and L with wire, turn the ind's on if they come on and stay on (not flash) switch should be ok.
When you say the flasher unit works one, sounds like the switch is working and the flasher unit is stuffed.
Have you changed to Led globes etc?
Kris_man
VK
Yeah it was the flasher can. Thanks for the reply.
