vk ls conversion
VKL98
western side
VE GTS
hey guys,
putting l98 into vk calais
looking to track down a hose avail in aust that fits the vk 5ltr radiator to ls3 (top hose fits to drivers, bottom to pass)
i would expect that i need a straight therm housing
does anyone know what works and fits nicely
cheers
found this one below but not avail in aust and the shipping is the killer
http://www.commodoresplus.com.au/forums/topic/vrvs-ls-engine-conversion-general-information/
info on the lower would be nice as well
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
Bend a bit of wire to the shape you want and take it into somewhere like super cheap
and see what they have got. I had to find an odd length top hose once. I found a hose
that came off a Toyota.
VKL98
western side
VE GTS
cheers mate will do good idea
Heron SSV
Central Coast
I've got an LS3 in my VK and am using a VK 6 cyl radiator, the inlet/outlets are on the correct sides. I havent bought hoses yet, but like Keith said, use some wire to bend into the shape you need. I've seen some people either trim a hose to fit, or join two to make it long enough or into the right shape. you can also get swivel outlets to change the direction.
davemoni
mandurah
vk
hey guys,
cheers
I used a VN VP v6 top radiator hose.
