Latest Update and dyno runs
Ok time for an update
Blew that engine up, well broke the top of number 5 piston and split the bore.
Its time for a new motor. New block is a EFI 3.3 black block bored 0.030inch fitted with 7.5cc center dished hyper pistons wearing nodular Iron top ring with gap-less second ring and acl oil control rings. Crank and rods are std with acl race series big end shells. Cam is Crow solid grind 35872 set to 0.091inch lift @TDC via crow adjustable timing gears. Deck has been notched, o-ringed and all head bolt holes have been helicoiled and screw in studs fitted. A 0.040 copper head gasket will be used. And spray on copper used after annealing. Ill never use holymar on a copper head gasket again!!!
turbo12port stage 2 - Head will get some upgrades including more work in the combustion chambers to try and get less detonation at higher boost. Valves will be upgraded to 1.65 stainless intake valves, and 308 VN/VP EFI undercut 1.6 exhaust valves. exhaust valves will be backcut. Moly retainers and locks fitted and new crow HD single valve springs used. further port work is done to exhaust and inlets are pocket ported with short turns radius. Head will be finished with new 3 angle valve seats and new o-ring wires fitted.
Some other changes will be BDD needles for the SU's replacing my BAX.
Ive made a photo gallery of the head build
HERE
That was the plan BUT...Had a huge change of direction with the cam. I now have a Clive Cams 280 duration 282 lift hydraulic grind fitted. Ive set the timing +2 to give 0.058@TDC. Its not what I wanted as I would like to have run with a solid grind. But after a final inspection before I was going to fit it, I found a screwed lobe on the Solid Crow ..... Damn... !!!
So its back to the dyno 175rwhp damn seems it has good AR until 5psi boost then just goes too lean.
So in goes a set of 0.125thou needle and seats to try and increase the fuel flow into the carbs. I measured the old ones and they seem to be 0.040thou so that should make a difference.Soo of the dyno again
You Tube vid of dyno run
235rwhp is getting better but is still leaning out just when I dont want it to.
Next mod is to fit a boost referenced fuel regulator. After looking around at what was available I chose the MagnaFuel MP-9690 and fitted it in l
Seems I need to do more research on how these things work!! At first when I set the pressure I did it with the car at idle ie 14hg vacuum so as soon as the vacuum starts dropping it thinks its boost and floods the carbs too early.... So turned off the engine and just ran the fuel pump. Reset the pressure to 5psi and started the car, well seems the regulator reacts to vacuum by dropping the fuel pressure, soo at idle it has almost no fuel pressure and trys to stall when pulling up to lights and stuff.
If anyone reading this has some experience with this kinda thing feel free to post up.
