Vk v6 pedal boxes
Daniel.steven
33
New zealand
Vk
Hey there I have tried to find a thread about this but have no success any help would be awesome.
I have a t5 behind a 304 in a vk but using a v6 pedal box seems to be ok but first and reverse and bit crunching if anyone else is running this set up advise will be mint. Thanks
gtrboyy
vt ss & lc gtr
Crunching may need more clutch adjustment or tired worn box.
Can also try holding pedal down then putting it in 1st/2nd before reverse.
6cyl pedal box still works pivot points are different which may make pedal feel harder to push in(?)
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
6cyl pedal box won't fully move the clutch throwout lever (longer in V8s) as far as it should go
= crunchy gear changes
the V8 pedal box (different pivot point and longer cable hook) is a must
gtrboyy
vt ss & lc gtr
Interesting as years ago sold couple of 6cyl pedal boxes to blokes doing manual v8 conversions even after telling them pivot points are different & could take their auto pedal box to Dellows to get converted properly.
Is common for tired t5 box to crunch,2nd to 1st or reverse trick seems to work most times.
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
Just as important is to set up the clutch fork "position" correctly!
Edsta69
45
hobart
VB vacationer
A v8 clutch has more movement 10 or so mm as apposed to 6cyls only having 6 or so mm for operational clearance hence the different pedal pivot points .........
