VK SL 3800
Hi
Was looking under the bonnet of my commodore trying to find what caused it to idle a little fast sometimes, and found it to be a little vacuum operated stop thing not retracting properly.
Its up the back near the choke and is mounted on a bracket that bolts onto the carbie using the two carbie manifold mount bolts on the passenger side near the EGR valve. it is not related to the choke and cant see the purpose of it unless its some sort of emissions thing. It has consant vacuum at all times and has a little rubber tip where it pushes on the throttle arm. can anyone tell what its for and if i just remove it would i have any problems.
202 black motor.
202 black motor.
