VK Wiring Diagram needed
lenie33
VK CALAIS
Im in need of a wiring diagram for a VK Calais, I am having problems with headlamps have no low beam, have high and park. If anyone has one they can email me at [email protected]
ENV5
VS Exec, VC SL/E V8, 2x Lada Nivas
have a look at your low beam fuse
brohawk
adelaide
vp calais
dude i have the same problem i found with mine it was the plug that is under the shroud on the bottom of the steeringwheel. its a large flat plug i found the bashing the bottom shroud in the right place makes them work. ill try to fix it properly 2moro and get back to you :D
