VL 6 to V8
dave977
HOLDEN over a ford ANYDAY
Bundaberg
VL Berlina RB30
Does anyone know what 308 block is the best to use with vn + heads with 4 barrel manifold for a VL Berlina 1988, in QLD.
greenfoam
99
VP Executive R-spec
Any of them work, but the VN block is slightly stronger/better not that it really matters. If you are bolting it to a trimatic get the earlier block
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
im with foam put the vn block there just about getting to be dim a dozen and more reliable
sed8
commodore nut
brisbane
vr ute @ vk calais
as foam said depends if your using the trimatic then you will have to stay with the assie pattern block, if you have a factory v8 vl then this is you block pattern, unless you want to change boxes then your options are endless
