VL Bt1 V8
hannon
Donating Member
45
new zealand
VL executive BT1
Hi I am new to the Just Commodores. I recently finally got my Bt1 home from been Barned for almost 8 years in storage. i cant find much about it on the web. there's many BT1 turbos but i cant seem to find BT1 v8
i would really appreciate if someone can give me the history/info on this type of commode
Thank you
Full noise
53
Hunter
VS ute
Pretty sure SA got the blue V8s, what do you wanna know?
Great classic should Brock the motor and keep the exterior stock.
tml678
2017 HSV30 Senator, 2002 Corolla..
Id just restore it to factory spec. Lots of modified VL's around. Good, matching number originals not so much.
Full noise
53
Hunter
VS ute
I think its supposed to have grey molds n bars SL tail lights and not blacked out side windows like some people do, any pics?
hannon
Donating Member
45
new zealand
VL executive BT1
Wow thanks so much for messaging me first of all. I found an old post that had many of the build sheet numbers and the body numbers , but what i want to know now is how do i find out if the engine is original to the body?
i do want to keep it as original as possible. i read a couple of articles that suggest the engines were either 4.9s with brock heads fitted or ss engines fitted
the build sheet is damaged but i can read LV2 on the sheet and tags so going of the post details it said maroon ss. But any how i need to ID engine first VJ570315 and VLKVK19-BT1 Any help greatly appreciated . i already donated to this great site will do so again
Thanks again
hannon
Donating Member
45
new zealand
VL executive BT1
Thanks for reply , i plan on keeping original mainly due to budget. suprised to see aussies stuffing gens in nice models , not many decent spec VLs in NZ so don't see that many on the road
hannon
Donating Member
45
new zealand
VL executive BT1
sorry forgot to rotate , not done any forum things before.
Full noise
53
Hunter
VS ute
Needs a makeover but awesome starting point, CSAs period correct
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
Rightio
VJ engine preifix is a 304 in a VL so most likely original motor. And the motor is painted black factory. 122 kW
