VL calais eyelids
VLC86
..stay N/A..
VL Calais
anyone know a possible cause for my calais's pop up lights not to work? the lights will be
on but the eyelids wont be up. i know the motor works perfectly because i can manually
wind them up, and when the battery is connected up again they close themselves.. but the
lights work just fine so somehow the power isnt getting to the motor. is it possibly the
relay? how could i check whats going wrong? anyone been able to fix the same problem?
detox_nath83
Another VL Driver
40
Queensland(Sunny Coast)
VL Turbo Commo
i would think its not a fuse problem as they close when powered, thus being connected, maybe a sticky relay yes or a bad connection to the motor from relay, use a multimeter to isolate the problem
Lazza78
Banned
SE bris
VT HBD LS1, VL calais project
the relay is a common prob with the eyelids... relay is behind the drivers side headlight, there is 2 or 3 relays there.. try one of the other relays in the eyelid one and see how ya go..
Larry
vn_v6
Blumpkin
victoria
87 vl limited edition
neighbor had the exact same problem, its the relay, went wreckes, got handufl of same coded ones and fixed the problem
VLC86
..stay N/A..
VL Calais
hey guys. i got it working, i tried the few relays near the battery and found the right one.
thanks for the help ;)
