VL Commodore - Ignition switch won't go to Accessory position
rebel_shadow
VL Commodore
New member - treat me gently!
I have just put a new ignition barrel into my 1988 VL and found the information in this forum most helpful.
My problem is that neither the old barrel or the new one will turn to the Accessory position.
Out of the column, both barrels turn to the Accessory position easily, but as soon as I put them in they won't go past the Off position.
Any ideas would be appreciated!
premium
P-Plater
Williamstown, VIC
1988 VL Berlina, 1985 VK SL
Pretty much every barrel in pre-VN Commodores/Calais/SLEs is stuffed by now, my VL can be readily started with my VK keys, and my VB SL/E can be started with my house key, and accessories doesn't work on the VL/VK.
jatsvl
NEEDS MORE POWER!
vl exec wagon
if you replaced it with a NEW barrel I would say your ignition switch (not the barrel) is worn.
nemesis_adrasteia
better to reign in hell
longford, victoria
VR commodore HSV(without all the gay ****)
it may be the switch.
also my mates car did a similar thing ended up being the rod parton the side of the steering column, itd slipped out of its position and wouldnt allow you to turn the key past a certain point
