VL Diff and Brakes Help.
pro_gmh
33
SA, Mount Gambier
VL
Hey all, i was putting in my minispool today and while taking out the axel shaft i noticed my brakes are stuffed, and then i didnt make them any better by bashing them and using them as leverage to pull out the shafts. Anyway, i thought i would look into replaceing the factory drums with discs. What will i need to fit discs onto my vl? (rotors, calipers, caliper brackets etc etc) can someone please elaborate.
btw i i have a 25spline with 3.45's - minispooled. Ive also started my vlt conversion today and interested to see how long it will take to fcuk up my diff and then my tranny which will soon have a cooler. However many people have told me that the na auto tranny can hold up and a cooler and properly maintained, but the diff ive heard mixed opioions, i might have to invest in a 28 spline but im no interested in upgrading the diff just yet.
Lastly, has it always been hard to get the shims and bearing cups back into the diff?
pro_gmh
33
SA, Mount Gambier
VL
Would the 28 splin axles fit in the 25 spline center with a 28 spline spool? or in other words, are the 28 spline shafts the same thickness?
Stewart1000
work done by ME
vic
www.justcommodores.com.au
VL twin turbo. VN5L. old jeep, **** mondeo.
not sure abput the shafts, i'b be calling up all the wreckers around your area tryign to see if they have any calais diff's or a calais you can go and pull it out yourself, i found one at my local wreckers the other day.
i reckon if you get a good service done on the auto and run a big cooler it should be good.
pro_gmh
33
SA, Mount Gambier
VL
Why calais diffs? they should be the same as my SL unless it was turbo or 5.0L.
