Vl manual conversion help!!!
Tyson1vl
Vl
Hey guys iv just done a manual conversion on my 88 vl executive.
Using the old ecu
I have bridged the neutral switch
Wired up all the engine with original loom but there’s 2 earths that I’m unsure where they get bolted to
It turns but won’t fire hoping they may have something to do with it any help would be much appreciated
_R_J_K_
Zenki S14
Have you tried earthing them to the engine or chassis?
Tyson1vl
Vl
Yes I did but it didn’t change anything didn’t make any sound difference to the engine when cranking either. I did have them hooked up to the alternator and when I hooked the battery up the dizzy plug started to smoke I took them off, then rewired the plug that started smoking. Iv checked over the loom and everything’s hooked up right. I’m just hoping it’s these two wires not earthed out properly
