Brenno85au
- Feb 22, 2005
- 95
- 0
- 0
- Age
- 38
- VL Commodore
Hi guys- i do need some help here big time!!
i have--> a VL commodore wagon, 5 speed manual Rb30 Stock motor
My problems-
HIGH FUEL CONSUMPTION- excessive black smoke on frequent occasions
NOT START WHEN IT HAS LESS THAN 1/4 TANK OF FUEL(i put more than a 1/4 in and it will start again- definately has fuel in it and is not a faulty fuel float sensor thing)
GUTTLESS RUNNING- This car has the power of a four cylinder and the fuel consumption of a V8
ok now here we go-
This car has run like this since it was bought over a year ago these are the things i have replaced:
I have replaced the FUEL TANK, FUEL PUMP, COIL, COMPLETE DISTIBUTER(crank angle sanser and so forth), oxygen sensor coming off of exhaust manifold, ENGINE COMPUTER, LEADS & 4xsets of spark plugs, AIR FLOW METER AND SENSER AND COMPLETE PIPE ASSEMBLY TO AND FROM, NEW POD FILTER, NEW HOSES, ALL FUSES AND RELAYS, BATTERY+TERMINALS.
After all of this- the problem is still exactly the same as wot it was when i first got the car!!!!! So....i took it to a few mates who are good mechanics, they were stumped! So i took the plung and decided to take it to a mechanics place- they had it for a day, rang me back told me 2 injecters were stuffed and told me it would cost $250 to overhaul them. So i told them to go ahead. I get another call back saying that four of them need overhauling and it would cost $450 so i said ok.
Well i picked it up and drove it for about a kilometer and had to get it towed back there the next day for them to inspect.
IT TOOK FOUR DAYS WITH 7 DIFFERENT MECHANICS THAN INSPECTED IT TO TELL ME THAT THE ECU CHECKED FINE AND NO PROBS, THEY DID A COMPRESSION TEST AND THERE WAS NO PROBLEMS, THEY DID A FUEL PRESSURE TEST AND THERE WAS NO PROBLEMS EITHER.
So the outcome was- they didnt know, i got the sh*ts with them for taking so long and went and picked it up.
i have tried collecting the return fuel and this makes no improvement, the fuel i use is always good, the reason i went thru so many plugs was cause they would foul up within within 5 minutes of driving when it spits out fuel smoke from the exhaust- but i later realised when it isnt blowing heavy amounts of fuel out, the plugs actually clean themselves up.
registration is in one month- i've spent to much money on this car and i just fell like i wanna :cry: all the time help me!
If you need any more information ask and i shall tell as im going to go insane and i need this fixed!!!
i've also checked fusable links,
if it doesnt work soon im just gonna throw a match in the piece of ****
thanx people :b:
My problems-
ok now here we go-
thanx people :b:
