VL no spark
iank
VR
Hi guys,
My trusty VL went to start this morning no go, no spark
Dist turns Ok
no pulses to primary of coil.
I cant find my wiring diag/schematic amongst my stuff.
A friend has the ws manual but its an hour each way to pick it up.
So I guess need to see if pulses are present out of dist back to EFI (connector pinouts) please as a starting point. From memory I think there are 1 degree o/p pulses as well as other angular data.
If any one could send me the wiring schematic I would appreciate it.
cheers http://forums.justcommodores.com.au/images/icons/icon8.gif
Angry
VLturbs87
1 TUFF SLE
VH SLE 333 stroker
check ya coil, check your dizzy, and the module...
If you check all them last thing can be chank angel sensor??
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The CAS is a likely candidate, that and the ignition module.
detox_nath83
Another VL Driver
40
Queensland(Sunny Coast)
VL Turbo Commo
Few Things. Try Another Coil.
And plugs on Dizzy and Coil. i have marked in red in attachment.
I had same problem a few years back and all i did was unplug these 3 marked and sprayed RP7 in them as one was corroded and it kicked straight away.
Good luck man
detox_nath83
Another VL Driver
40
VL Turbo Commo
Sorry Please delete previous Post as i forgot attachment.
Good luck man
anothercarnut
1988 Holden Commodore Vl GTS
well i have just inherited this problem with no spark. i have replaced the dizzy cap, rotor, ignition coil, the sensor beside the dizzy, is there a way to check the crank angle sensor with a multi meter to know if it is working? or any other idea that may be a factor?
mag
60
South OZ Adelaide
VY Series 1 Acclaim 2003
vxss01
vl calais01
vl calais
hi got the same problem checked and replaced dizzy and coil other thing
there are no leds lighting up on ecu could this mean the ecu is the fault
thanks
mag
60
South OZ Adelaide
thanks
If you have no LEDS lighting up then yes it could be the ECU is stuffed but I'd check wiring and plugs 1st~do you have rust around the base of the windscreen if so water may have been leaking on it...:thumbsup:
vxss01
vl calais01
vl calais
vl wont start
hi no trere is no rust in car at all amazingly and no sign of water leak thanks
