Vl Not running past 2000 rpm HELP
TheChad
Vl Executive
Hi Guys, I am trying to get my Vl to run as it has been sitting for a long time with stale fuel in it, I can get it to start, and Idle althouhg roughly, but if you accellerate past 2000 rpm it stalls, I ahve cleaned out the fuel tank, put clean fuel in, replaced the hoses for the fuel reservoir, any uggestions as to what would be causing this to happen and how the hell am I going to rectify this problem?
Thanks
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Thanks
Do a computer test first mate and see if theres any error codes.
search the threds here youll find out to do it! or google it. ;)
TUF UTE
Dave
adelaide
05 VZ SENATOR
blocked fuel filter. dirty injectors, loose battery terminal
woodyotoad
Queensland
Vs commodore
check your exhaust isnt blocked 2 aye, i had that hapen 2 me
vt_ss_5l
Banned
Northen Subs Melbourne
Vx SS Gen III
100% Its The Air Flow Meter If its Stuffed The Car Will rev to 2000rpms Then Start Surging There Cheap on Ebay !
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Check that the air flow meter is tight too.
ditch_12
VL ridin 18s
had same problem with mine and was just a wire to the airflow not connecting so try wriggling the wires around yours first, saves buyin a new one if its that
