VL rear disc conversion info needed
abcent
VL Berlina S2
I'm considering converting my VL to a disc brake rear end, going from a VK calais to drum rear VL you notice just how crap the drakes are.
Anyone done this? know whats required?
1: do I need a different master cylinder?
2: can I use my drum diff an just change the brakes? or is it easier to find a disc diff an put it in?
3: are the drum & disc diff yolks the same?
any other extra info you might have would be much appretiated
thanks
Berin
bangers
42
NSW
EL FALCON XR6
keep the rear end. just need hand brake cable, hubs, discs, calipers, backing plates, brake hoses, and bearings (i think). don't necessarily need bigger master cylinder but it would help.
BigDaz
34
Nsw - Taree
VT Calais
i did the convert on my beast but i had a complete VL calais rear disc diff here so we just needed the new handbrake cable and then just bolted it all up and in. DIDNT change the master cyl, no brake rubbing at all and have since put new pads in and still no rubbing. If u can get the complete Disc diff it would prolly be easier but its up to u mate :)
minimefx
45
vr wagon, vx executive
vn discs do bolt on with a disc brake seal kit and straightening out of bake lines and adjustment of hand brake cable. been done many times before by vl owners and me.
bangers
42
NSW
EL FALCON XR6
the vn rear end may be a little wider (?). no problem if it is, just watch your rim offset.
G
Grantis1976
Guest
I have no idea if other brakets are needed too.
Is the backing plate identical?????
Is the wheelbearings different???
Why dont brake shops do this/answer these questions???
Who killed Kenny ?!
If you find these out, please let me know too, after going from a VN Calais, to a VL drum bum, you do notice a big difference.:bang:
BigDaz
34
Nsw - Taree
VT Calais
The bastards killed kenny didnt they? :yeah:
I dont know the other answers but :whistling
irws85
Bundy
VS Commodore
V6 ecotec - vl (brake upgrade)
Need Info on upgrading the front and rear brakes, I have a complete 95 VS COMMODORE live rear axle.
I'm converting the engine into a VL Commodore and need to know if i can use my brakes from the VS to upgrade the VL brakes or do i need to buy a VL turbo brake package??
and if so what is needed for the upgrade and how much?
neo
46
VY_SS_Black
hey abscent - Make live easy, get a complete VL Calais or Berlina rear disc brake diff/axle assesmbly (I got mine from a place that specialise in Toowoomba). Unbolt the old drums, bolt in the new discs. (4 bolts from memory). Be smart, and upgrade the booster and master too - don't skimp on brakes as they will save you one day!
Apparently here in QLD you will need a Mod plate for this too - but if no one knows then.....
vlv8vic
<---Brad Quaid = internet stalker
Australia
M5
neo as long as you realise the original post was put up here nearly 3 years ago. I'd say he has it sorted by now.
