VL Rough Idle, Stalls under acceleration!
Scrusy
Nambucca Heads
VL wagon
When I had this problem I brought all new parts Including:
Fuel regulator
New fuel lines everywhere (approx $35 per metre)
Fuel filter
Oil filter
New oil
Spark plugs
Ignition leads
Air filter
Throttle body cleaner
New radiator fluid
Was a bit excessive to buy all those things. But it fixed the problem and also got a decent service out of it too :)
detox_nath83
Another VL Driver
40
Queensland(Sunny Coast)
VL Turbo Commo
Search is your friend. Been answered many many times its like we r on repeat.
Check all your intake piping after the afm all clamps are right no air leaking around rubber grommet where idle air is sucked from ( long thick rubber hose that travels the length of the intake piping) also any cracks in the constantined piece after the afm
markER717
Un-Donated Member
Geelong, Victoria
1990 3.8L VN Calais S1
Take it to a mechanic I guess. You gotta remember, these cars are what, 25 or something years old, so half the parts on there are crappy anyway so you might as well fork out a few bucks for a part now, and potentially fix the issue, or keep trying to trouble shoot, but I can't think of anything else you haven't tried
Yeah I guess thats my next option, I want to try to replace the fuel reg first, if its not that I guess its straight off to the Mechanic. Thanks for your help you did help me getting it running slightly better.
Fuel regulator
Fuel filter
Oil filter
New oil
Spark plugs
Ignition leads
Air filter
New radiator fluid
Out of your list, the fuel reg is the only thing I haven't replaced. Its next on the list. Thanks! :)
Actually I did search, many times actually, and most of the results I received where: CTS, AFM and CAS. All of which I had already replaced plus many more suggestions (from other threads) before I made my own thread as I didn't want to dig old threads (can't dig old ones, can't make a new one.. can't win? lol). If you bothered to read the rest of my thread, you would find I have already checked those things, but thanks anyway. :)
87RB30VL
Swiggidy Swag
37
North Brisbane
www.facebook.com
09' FG XR6 Falcon, 75' HJ Kingswood Ute
I hate the search function, it never finds what I want, half the time I just go to google and search "Vl won't start Justcommodores" and that does it for me haha
But yeah I'd be suprised if it wasn't the reg after everything you've tried
detox_nath83
Another VL Driver
40
VL Turbo Commo
Looking good man. Good to c ur still tinkering with her and the missus hasn't sold it on u hahah. That the catch can I gave u or did U get another to suit with the filter?
All we need to do is the 3" exhaust and she will breath better and have more poke
87RB30VL
Swiggidy Swag
37
North Brisbane
www.facebook.com
Lol you know this isn't my car thread right? But yeah I just got a fitting from supercheap, screwed it into the small hole, and clamped a pod onto that, and the big red cap end is at the bottom. After I stuffed it with steel wool of course :p
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
I have the vac line for the aircon controls disconnected would this have that drastic of a problem?
Did you reconnect the vacuum hose for the A/C. This usually has an effect on how the car runs, as it is getting more air than it needs.
Any vacuum leak or hose off will effect how the car runs. Especially on low revs.
Scrusy
Nambucca Heads
VL wagon
I took my air conditioner out and all the lines that came with it. And now I'm having problems aswell. If u havnt already read my thread, missing and spluttering. Starting to get the shits with it as everything I've done hasn't fixed anything
RB30_VK_CoNvIk
RB30DE+T
Waipukurau, NewZealand
1984 VK Commodore RB30DE+T
um when you disconnect the AC from a RB30/20 you have to turn the AAC valve screw anticlockwise 270 degrees, dunno why but in the gregories book it just tells ya to under any disconnection of any air hoses reflects on the AAC and idle control valve, you dont have to replace anything
