Hi,
I'm building a VL track car and wanted to know if anyone has any experience with front and read spring rates for an early commodore. If so what have you been using?
Car is RB25DET and will be running on semi slicks. Probably be using BC coil overs.
Thanks,
Greg
ok.. you have provided most of the info needed.
firstly, set spring rates to suit your tyres
secondly stiffer/tighter/harder is NOT better.. any time! (talk to Larry or Jack Perkins if you disagree)
third.. do not set spring rates around sway bars (do the reverse)
Forthly.. don't do much with street type springs if you are serious . A proper coilover will outdo an SSL... anytime!
Fifth... set springs before getting shocks (and get shocks that can be revalved or are adjustable)
Six... how much does the car weigh? have you changed the weight distribution from factory? (battery in boot etc)
and
finally, make the final choice based on your actual suspension. What toe? what castor? what camber?
what akerman? CV jointed rear axle? spool?? and be prepared to change it .. if you move to slicks or if it rains
Final hint ... always aim for driveability, having to wrestle with the car means it ain't right! Mine is hands off at 200+
down the main straight at Sandown (if you want)
and
sorry, I am not giving you my settings .. my VK will weigh more/less and have different suspension set up to yours
