VL walkinshaw replica 666-GMC
*uwishn*
Holden special vehicles
sydney
vl walkinshaw(replica)nissan navara d40 st-x turbo
ah that's why then,you went with the hydrolic set up i have the cable set up.
more pics!! lol
stephen52520
busselton
vl commodore
hi mate
i am just starting putting on kit
can you help me out have some questions re the kit
what did you do behind the front top lip as they is a big gap no fixing point ?
also how did you tidy up the edge on the quarter window in side the door ?
any help would be great
cheers
twr-92
VL walky replica, ve sv6, vy s
by front top lip do you mean the front bar?
my front bar / spoiler had mounting points moulded into it so I could screw the reo bar into it.
the lower lip had no holes drilled. I drilled 6 points through the front bar and lower lip and screwed them together using some large diameter washers on each side.
My c pillar panels needed to have some glass removed from them too, I used a belt sander, drill and file for different areas depending on the location, how easy it was to get a tool in there and how much material had to be removed.
good luck with it. do you have a thread where you are posting pics?
seeing others progress is good inspiration.
stephen52520
busselton
vl commodore
what was meaning at the top of the bumper center to the head light area center
did you make a bracket ?
twr-92
no, I mount the front bar to close the gap as much as possible by adjusting where it bolts to the chassis.
I also used a couple of zip ties between the reo bar and the grill bracket to give the last little bit of lift. the gap didn't completely close on my car as I've put a Calais front on.
I suspect the exec/berlina front has less of a gap to deal with
stephen52520
busselton
vl commodore
it looks like i will make a bracket to screw too
do you have a picture of the quarter window area inside of door so i can see how you finshed off please
thx
twr-92
my new radiator arrived today, an ignition control module is on its way and so are some boxes from v6conversions to send a speed signal to the ecu and drive a motor in the back of the speedo.
I can almost see the light at the end
*uwishn*
sydney
after a few colorful words, the gearbox is attached to the engine and its mounts.
told you they are an absolute pig lol. one of the hardest you have done also?
flood this thread with pics please!!! :)
twr-92
more pics
This is the VDO speedo and ratio interface that v6conversions sent.
I'll try and fit the speedo into the vl instrument cluster instead of mounting it infront of it.
I think its been done a few times before. I hope its as easy as cussing a round hole in the face, removing the existing speedo and tightening the screw on ring behind it.
