VLT won't start, i'm at my wits end I swear
Discussion in 'VL Holden Commodore (1986 - 1988)' started by 87RB30VL, Apr 17, 2013.
  1. 87RB30VL
    87RB30VL Swiggidy Swag
    North Brisbane
    09' FG XR6 Falcon, 75' HJ Kingswood Ute
    Yeah marked my old one before and after I pulled it out, and marked the new one in the same spots and after she went in she lined up perfect.
    Checked the timing belt, she looks pretty damn good, must have been replaced, no cracks or missing teeth.
    I do have a constant high pitched beeeeeeep from in my bay when my key's on and the pump's finished priming
  2. Scrusy
    Scrusy New Member
    Nambucca Heads
    VL wagon
    Just a quick thought. Have a try of the grub screw in the back if the plenum. I had a fiddle with that when I was having problems and fixed the rough idleing issue.
  3. Tikkat3
    Tikkat3 Member
    VZ SVZ Wagon
    Sounds like the crank angle sensor in the dizzy
  4. 87RB30VL
    North Brisbane
    I changed the cas 3 times plus the whole dizzy including cad out of a working engine but still no luck
    Sent from my HTC One SV using Tapatalk 2
  5. 87RB30VL
    North Brisbane
    Gotta get it running first lol
  6. Scrusy
    Scrusy New Member
    Nambucca Heads
    VL wagon
    Aw true I havnt been reading everything lol must of missed that it dosnt run anymore ha
  7. Tikkat3
    Tikkat3 Member
    VZ SVZ Wagon
    Check the electrical plug that connects to the dizzy. The rubber boot deteriorates and water gets in and corrodes the terminals. Was a common problem
  8. Tikkat3
    Tikkat3 Member
    VZ SVZ Wagon
    How much fuel came out when it cranked?
    Was the pressure high and was there plenty of volume?
    Try squirting some aerostart in the manifold and see if it will start. If it's got spark it should at least fire for a short time
  9. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    If the plugs were black when you took them out, then it is getting too much fuel. Fuel pressure regulator might have died.
  10. 87RB30VL
    North Brisbane
    She filled half a bottle of powerade in few seconds so it was coming out alright, and pump cuts out after few seconds so she has pressure. I'll grab some start ya bastard tomorrow and spray that in the intake and see. I've tried fuel in the intake, and also fuel in cylinder 1 through removed spark plug, put it all back together but not even a short run, just kept cranking.
    Yeah she runs rich, always has since I turbo'd it, only have the na ecu and injectors fitted, and afm after the turbo so it's probably trying to squirt more than it can burn
  11. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    I had issues with rough running it was a vacuum leak from a cracked line next to the manifold and also made my spark plugs black
  12. 87RB30VL
    North Brisbane
    Cheers for the tips guys, just bought a new set of leads, about to put them on then test the injectors for pulse
  13. 87RB30VL
    North Brisbane
    Ok so my fuel pressure regulator was fine (pulled the top hose off, primed engine, no fuel came through so it isn't leaking), placed an LED in my injector plugs and had my wife crank the engine a few times, each injector plug caused the LED to flash on all 6 injectors, so it's getting pulse. It has spark. It has fuel. Even if the timing is out, it should still start, even for a few seconds, or even just running like ****.
  14. cracker
    cracker New Member
    if your timing is miles out it wont start.
    sounds like the dizzys teeth are out of synch with the drive gear? have you looked at that?
    also its quite easy to foul a set of plugs and it wont run either.
    another stupid thing to consider is blocked exhaust - cats broken up/melted.
  15. 87RB30VL
    North Brisbane
    I'll have to get someone with a timing light to come have a squiz at my timing to see if it's way out.
    The plugs got put in yesterday arvo, but I will have to take them out to compression test the engine anyway so I can suss them again when they're out.
    Also, I uhh, have a gutted cat lol
  16. Scrusy
    Scrusy New Member
    Nambucca Heads
    VL wagon
    High flow cats are wayyy better, u should get urself one. I put bought one a month or two ago. Gives a better note and u don't get that tingy popping sound when going down a hill in gear. But obviosly mine would sound different with extractors and that when urs is turbo
  17. 87RB30VL
    North Brisbane
    I would but I'm selling the VL once I get it fixed anyway, my 3" exhaust gives a mad low rumble when I drop down a gear going downhill, sounds pretty boss cos it's straight through from the turbo back haha
  18. detox_nath83
    detox_nath83 Another VL Driver
    Queensland(Sunny Coast)
    VL Turbo Commo
    I second the timing it's either 180 out or out of sequence. Dizzy out push car over till 1st cylinder is at tdc slide in dizzy so rotor arm points to lead post 1 on dizzy. Then fine tune in with a timing light. U have fuel spark compression it's the only thing is spark timing
  19. Tikkat3
    Tikkat3 Member
    VZ SVZ Wagon
    Make sure its on the compression stroke and not the exhaust stroke. Put compression tester in no 1 cyl and turn over by hand and watch for the gauge to raise a little. Use a long peice of wire (coat hanger) down the plug hole to determine when the piston is at tdc.
  20. 87RB30VL
    North Brisbane
    Where do you crank the engine from on the RB30? Can you tell I've never cranked an engine by hand lol.
    So basically what you guys are saying, is crank the engine by hand, make sure cylinder 1 is fully up, put the dizzy back on so the rotor arm faces lead 1, then try it & if it's running, suss it with a timing light?
