yes i will of course, I'll replace the bearings
I meant give the crank just needs a polish
interesting the sump gasket was one piece seal, unless its been changed before, and few on sump bolts were not overly tight
the rear seal is non-rope and neoprene
was hoping to get to flat top pistons, as this VN aero is supposed to be 9.5 but cant see how they can get that with 0.040" gasket and 10cc dished pistons
I'm using 63 cc heads (92060019), pistons look to be original holden so assuming 1.71 Compression Height, according to ACL 4901 piston these are supposed to be 9.9/1 with 71cc heads (I cant see that)
With 0.020" deck height and its coming out at 8.3/1.
If I use 0.027" gasket and get another 2 points to 8.51
would like to be + 9.5/1, which seems to be the older acl piston # 9490 which is flat top
if pulling the crank to polish might as well take pistons out for hone and replace rings
not sure whether I want to go hydraulic roller or stay with Hydraulic flat tappet camshaft
