VN 200KW upgrades
immortality
Staff member
Sth Auck, NZ
True. Mine mostly only leaks from the rocker covers.
bjf66
Mt Martha Vic 3934
VN HDT Aero
will remove oil gallery plugs and frost plugs
The block will be getting a nice hot bath of degreaser/hot water over the weekend in 200 litres steel drum and large gas burner under it and heat it overnight to get it boiling away
should get rid of oil and grime on inside of block and clean passages out to be sure
then use gurney to clean and dry then WD40, then see what it looks like
losh1971
North Tas
The Bus
immortality
Staff member
Sth Auck, NZ
Nahh. Mine looks ok at the rear main.
Deuce
Super Stock
'94 VR SS V8
No rocker leak on mine.
Rear main leaks (I would say this is my fault from before install of the engine - we live and learn)
And oil pump to block gasket leaks. But clearly can't use it twice after re-packaging the pump when it dropped oil pressure early on in engine life.
achoo
41
murrayee bridgee
vf vk calais sedan
not sure whether the hyd cam and lifters have been changed earlier as it had chilled iron lifters in there and according to crow cams yesterday they were NOT standard in holden although I could of misunderstood the statement
whats the cam number ??
bjf66
Mt Martha Vic 3934
VN HDT Aero
there is no number on this cam cant even identify it
cant even see where there is forging markings
achoo
41
murrayee bridgee
vf vk calais sedan
must be one of those secret sauce 200kw cams with the numbers sanded off that hdt used on the factory 8.4:1CR 304 motors
bjf66
Mt Martha Vic 3934
VN HDT Aero
You got in one
Sounds familiar
First thing first need to compression up to 9.50:1, then go from there
