VN 304 Master Cylinder leaking from switch/sensor
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by yatesy88, Jul 4, 2012.
  1. yatesy88
    yatesy88 New Member
    WAIKERIE
    VN SS
    hey everyone, could someone please tell me if it is possible to remove the switch on the master cylinder as mine is leaking from there and running down the wires onto the paintwork, if you can remove it please post how. Also i cant bleed my brakes cause where its leaking it must be sucking air to :(
  2. drewVHSS
    drewVHSS Donating Member
    Gosford Central Coast
    '83 VH SS, '79 Green VB SL '92 S2 VQ Caprice
    yes you can remove the warning switch to replace it. be careful as the plastic is weak.
    New m/c's have poor quality switches i've noticed which is a dissappointment considering how expensive they can be.
    Also when you're bleeding the brakes, if you push the pedal too far you can feel when you've gone too far and push the piston rod (inside the m/c) past the warning point that the switch detects.
  3. hsvwgn
    hsvwgn New Member
    Hoppers Crossing
    91 HSV Wagon, VP GTS
    Hi mate, there should be no brake fluid in that part of the master cylinder where the switch is located. If you are sure there is fluid leaking from the switch, the Orings are the problem and you need a new master cylinder or if that one is ok for reconditioning, put a repair kit through it.
    Good luck
  4. yatesy88
    yatesy88 New Member
    WAIKERIE
    VN SS
    well that sux, thanks for the quick reply everyone appreciate it. Looks like new master cylinder it is or repair kit. Does anyone know where to buy one (repair kit) and are they complicated to install cheers
  5. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Add Content
  6. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    Might be able to find a good 2nd mc from a wrecker for cheap
