vn 3800 rebuild help !!!!
james_sherman
frankston
vn executive
hey guys i have just pulled my motor our of my vn due to welsh plugs and i was just wondering what other stuff i should do to my engine why it is out and how hard are head gaskets to do on them the things ive thought of so far is.
welsh plugs
valley seal
rear main seal
head gaskets
rocker cover gaskets
sump gasket
thanks guys im a second year aprentice so it shouldnt be to hard thanks
VN S1
Valves and springs should be done while you got it out. Maybe even timing chain.
VN S1
Also if you buy a vrs gasket kit it will have nearly every gasket to do the motor.
james_sherman
frankston
vn executive
thanks man um where do u get the vrs kit the endinge has done 380,000 km and its on gas to so how much are valves and springs thanks
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Must do the timing chain tensioner - must!!
VN S1
Most brands have vrs kits, just ask when you go to order a set. I got my vrs acl tace series for 250 i think delivered.
james_sherman
frankston
vn executive
ok thanks pretty much how much am i looking to do all this stuff
VN S1
230 about for gaskets, 30 for timing chain tensioner, Or off ebay you could get all you need for 300.
james_sherman
frankston
vn executive
ok thanks it will help heaps is it hard to put the timing correct
88GreenVN
Next Exit Left
60
Surprise, Arizona
Also when the timing cover is off - look for corrosion behind the water pump outlet. I've had 3 Vn motors leak from behind this point.
